@#%$# Oil pressure sender!
Old Jan 10, 2009 | 10:32 PM
tpi305's Avatar
Car: 1986 Iroc-Z, 1980 Cadillac Eldorado
Engine: Iroc- 5.0, Caddy-5.7
Ok, I have 1986 Iroc-Z that has a bad oil pressure sender. On this car, it is located on the back of the engine, near the distributor. I can't unscrew it from the top, because the top just spins, while the bottom (the part with the threads) just stays stationary. So, I have to get at it from the fitting close to the bottom of the sender. There's barely any room at all.
Does anyone have any suggestions? Do I have to pull the distributor? I can't get the idle down to 600 (I cleaned the IAC, but I can't adjust it because I can't get the idle to go under 1000 or so. The throttle body won't close any more), so timing it would be quite difficult if I didn't get the distributor back in just right. Any suggestions that you may have are welcomed. Thanks.
Old Jan 10, 2009 | 10:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: @#%$# Oil pressure sender!
Maybe you can buy a cheap wrench and bend it to fit in there.
Old Jan 11, 2009 | 12:41 AM
tpi305's Avatar
Hmmmm, that's not a bad idea. I guess I could just put it in a vice, heat it, and bend it? Thanks for your help.
Old Jan 11, 2009 | 10:38 PM
recarosp's Avatar
Car: 83 Recaro TA/ 95 TA
Engine: 355 / LT4
Transmission: turbo 350 / 6 speed
Axle/Gears: 373 / not sure think same
if u take out the distibutor u will have plenty of room to chang it
Old Jan 12, 2009 | 10:53 AM
SIEB77's Avatar
Car: 82 TA
Engine: Slighty built 350
Transmission: T10
Take out the dist... Fix your idle problem..... Replace your sender.... Car will then be reliable and you will be happier
Old Jan 15, 2009 | 08:40 PM
SSWOLZ02's Avatar
Car: 92 Camaro RS
Engine: 88' L98 w/92 tpi conversion
Axle/Gears: Stock one tire Fire!
tpi305 they make dedicated oil pressure sending unit sockets that are deep enough and have the proper end for the sending unit.
Old Jan 15, 2009 | 08:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The socket turns it by the body, though.
Old Jan 15, 2009 | 09:12 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Not the ones my step dad has. But they don't fit in the tight area, so they are pretty useless on F bodies.
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
mddaniel
Sep 8, 2015 05:16 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
