Inlet Air Temperatur sensor
Old Jan 19, 2009 | 02:17 PM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
Ok I did the bad, as I was removing my A/C plug from my engine harness I actually removed the IAT (Inlet Air Temperature sensor) connector. I cannot find a diagram of the IAT system. One of the wires came from a common ground. The tan wire I cannot find how far back I took it out. The only thing I see is where it goes in to the computer. Is this the only place this goes?
Old Jan 19, 2009 | 03:41 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Inlet Air Temperatur sensor
Yup, the tan wire goes into the computer.
Diagram here if needed: http://www.austinthirdgen.org/mkport...ta_sensors.jpg
Hope this helps.
Lou
Old Jan 19, 2009 | 06:21 PM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
thanks
the diagram that you posted is for an E and I have a P engine.
Old Jan 19, 2009 | 07:16 PM
BigBadLou's Avatar
Engine: TPI
If P stands for LT1 then sorry, didn't realize. It's just a standard 3rdgen diagram.
If you need LT1 diagrams, I suggest looking on 4thgen websites, I'm sure you'll find it there.
But my answer is still valid: the IAT wire goes only to the ECM, no other places in the car. That should help.
Lou
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
92purpz28
Aug 11, 2015 02:30 PM
