No Oil pressure or Temp gauge???
Old Jan 24, 2009 | 03:58 AM
jfsiutza's Avatar
Car: 1986 Z-28 al unser silver bullet
Engine: 305 carbed
Axle/Gears: 3.08
ok i have no oil pressure gauge or temperature gauge and im wanting to fix it because i may really need those gauges..
i removed the computer.. the A/C .. carb set up on a former TPI 305. ever since the swap those two gauges dont work.. anyone got ideas on how i can reconnect those gauges????
1986 Camaro Z-28
Old Jan 24, 2009 | 09:46 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: No Oil pressure or Temp gauge???
Define "no gauge". Do you mean they disappeared from your dash?
I mean are they pegged left/min or right/max?
If the wires for these two gauges are disconnected from their senders, the gauges will stay at the minimum mark. I'd check the senders first. The temp sender should be in the driver side head, between the first two spark plugs. Most likely a dark green wire. And the oil pressure sender is on the back of the manifold/block, accessible from the driver side. A cylindrical looking object with a tan wire.
Hope this helps.
Lou
Old Jan 24, 2009 | 12:56 PM
jfsiutza's Avatar
Engine: 305 carbed
Axle/Gears: 3.08
they're there.. lol.. there min... i knw i removed the wiring harness when i did the carb swap.. so im pretty sure the whole wire to the sensors are gone... i dont know if i can just go from sensor straight to the gauge.. since most wireing diagrams show that the wire/s go through the computer
Old Jan 26, 2009 | 09:11 AM
BigBadLou's Avatar
Engine: TPI
Don't worry, the wires don't go through the computer. Or at least they "shouldn't".
Both wires should go through the bulkhead connector C100 right by the brake booster, in the corner on the firewall. Hopefully you didn't cut the wires too short so that you can solder onto them.
This diagram shows which pin and wire color to look for: http://92b4crs.tripod.com/86wiring/dia-pics/81-0.jpg
Hope this helps.
Lou
Old Jan 26, 2009 | 01:45 PM
jfsiutza's Avatar
Engine: 305 carbed
Axle/Gears: 3.08
before i sold the tpi unit yesterday.. i looked at the harness i took out.. the connections for the oil sensor stayed on the harness.. which used to go to the drivers side and in to the computer.. the harness left has the starter still hooked up.. and i found the temp sensor on the side with the AC hook ups... but i going to have to buy a new temp sensor.. theres no connection available...(broken)
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
