Engine Won't Crank Over
Car: 1991 Firebird Base
Engine: 3.1
Transmission: 700R4 Automatic
Took my bird into the school's shop to get the engine running, found out what I did wrong when I changed the head gasket, learned my lesson, but found out that my engine doesn't like to crank over unless my steering wheel is in the lowest position. Makes clicking noises and has electricity but doesn't seem to have enough unless it's down. Any ideas? My friend thinks that the previous owner messed up the wiring when they put in the non-stock cd player, you can see wires coming out the one side. He also thinks it might be the reason that my one headlight is stuck up and the other is stuck down, I'm not sure about that one, I've known these headlights to have problems with the motor before and I found a $0.50 fix for it online. Thanks.
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
Re: Engine Won't Crank Over
Sound like a vats problem.
take a look at this
ation
The Pass-Key, Pass-Key II, or VATS, as it's called in earlier GM vehicles, uses a resistor mounted in the key blank to confirm that the correct ignition key is being used to start the engine. Many people call the resistor pellet a "chip" due to the common misconception that it is some sophisticated digital circuit to identify the key to the car. Not quite. It is not a “chip” of silicon as is customarily used for integrated circuits, but merely a block of carbon appropriately sized to have a desired electrical resistance.
GM mixed about fifteen different resistance values in their pinning codes to add another factor to make vehicle theft more difficult. The resistor blocks are staked into the key bodies, just between the key bow and pinning cuts. If you desire a replacement key for a VATS equipped vehicle, they are available through almost any GM dealership. These are usually priced about 3 times higher than the same key can be purchased at any reputable locksmith. If you have a VOM (multimeter), you can measure the resistance of the pellet and inform the locksmith of the blank you will need, or simply allow them to test and match it.
Vats Key Codes & Resistances
(Ordered in KEY BLANK numbers from 1 to 15, Resistances in Ohms)
System Operation
When the system is operating in normal mode, the VATS decoder reads the correct resistance during cranking. The module grounds the Start Enable Relay coil. When the start enable relay contacts close, voltage is allowed to the "S" terminal of the starter. The VATS module also sends an enable signal to the ECM. This signal allows the ECM to operate the fuel injectors during cranking. The SECURITY light will also illuminate for approximately five seconds, then turn off and remain off.
If an incorrect or no key resistance is read by the VATS decoder module, the module will shut down the start enable and ECM signal outputs for 4 minutes. The SECURITY light will flash during the cranking attempt, and will remain on during the 4-minute duration. Even if the correct resistance is read within that 4 minute duration, the VATS module will not operate the relay or signal the ECM..An error code.53 will also be set if the proper signal is not being received on CKT 229 by the ECM when the ignition is turned ON.
If an incorrect resistance is detected by the VATS module after the engine is running, the VATS module will allow the vehicle to be restarted, even with an existing failure. The SECURITY lamp will remain on to warn the driver that a VATS system fault is present. However, this also means that the car can be started w/o a correct key resistance, and is therefore vulnerable to theft. An error code.53 will also be set by the ECM in this mode.
NOTE - This error code does not store in VRAM memory, but is only present while the condition exists, and is useful as a diagnostic tool in troubleshooting VATS systems.
To signal the ECM that a correct key resistance is sensed, the VATS and PASSKey systems use a grounding square wave at a 30Hz rate. The VATS module uses an NPN output transistor to pull down (ground) the 5 VDC reference voltage presented by the ECM on terminal B6. The reference signal must be alternately grounded and allowed to be pulled up by the ECM internal resistor 30 times per second (30 Hz) and at a 50% duty cycle. This method was selected to prevent the simple powering or grounding of an ECM input to enable the fuel injectors. The signal is only needed during cranking to enable the injectors. Once the engine is running, the VATS signal can be removed and the engine will continue to operate normally, although with the SECURITY warning lamp on.
The PASSkey-II signal is a similar square-wave pulsed-ground, but at a 50Hz rate, 50% duty cycle.
Circuit Description
The system uses two leaf contacts in the outer end of the ignition lock cylinder to connect to the resistor pellet embedded into the key blank just below the bow. The wiring from these leaf contacts travels down along the steering column wire harness, where it connects to the vehicle harness at the base of the column. Usually, the VATS wiring in the column is in an orange covered cable, sometimes black, and has a lone two-wire connector (no other circuits in the cable). The circuit continues from there to the VATS decoder module via purple/white and white/black wires. The VATS decoder module is located beneath the dash in the LH foot well, near the kick panel.
The VATS decoder module has sixteen connector pins, but uses only eight wires:
Diagnosis & Test Procedures
If the engine WILL CRANK and a code 53 is displayed, that indicates that the VATS decoder module has detected a correct key resistance, and has grounded the relay coil negative wire for the start enable relay, but that the ECM is not receiving the VATS signal from the module. That can be caused by either a failure of the VATS module output which generates the signal, or Circuit 229 between the VATS module and ECM is open or shorted to ground.
If the engine DOES NOT crank and a code 53 is displayed, that indicates that the VATS decoder module has not detected the correct key resistance, and therefore has not enabled the start enable relay, or there is an incorrect starting procedure.
It is common for the leaf contacts and/or the resistor pellet on the key bow to become contaminated to the point where the VATS decoder module cannot correctly sense the pellet resistance, or cannot sense any resistance at all. This would usually cause a no crank/no start situation. Cleaning the key pellet and leaf contacts can frequently restore system operation. Because of the risk of contamination and other reasons, NO liquid lubricants should ever be used on the ignition lock cylinder. The generally accepted lubricant for ANY lock cylinder, whether a plate or pin type mechanism, is powdered graphite ONLY. This especially applies to VATS ignition lock cylinders.
It is also common for the two wires from the ignition lock cylinder contacts to break due to the necessary flexing which occurs every time the ignition lock is moved. This can usually be diagnosed by measuring key pellet resistance at the VATS module or at the connector at the base of the steering column.
There is a small two-wire connector in the upper bowl of the steering column which can become damaged or disconnected as well, since clearance between moving parts in the upper column bowl are minimal.
The connector at the base of the steering column can fail if subjected to stress, moisture, or movement if the lower bolster trim is not in place.
The connector at the VATS decoder module is generally reliable, and the connection at the start enable relay is also relatively safe from interference and reliable. However, all connections should be checked when diagnosing the system since any connection can fail or add resistance to the circuits. The start enable relay itself is a mechanical device, and can fail after prolonged use.
The following diagrams and charts may be useful in understanding and diagnosing the system:
take a look at this
ation
[IMG]file:///C:/Users/Bryan/AppData/Local/Temp/moz-screenshot.jpg[/IMG]
Circuit Description
- An orange wire from B+ for a constant 12VDC to pin B8
- A purple/white and a white/black wire from the key contacts
- A pink/black wire from the ECM/IGN power fuse to pin A1
- A dark blue wire connected from pin A2 to the ECM pin B6
- A gray wire to the “SECURITY” lamp in the instrument panel from pin A4
- A yellow/black wire to the start enable relay operating coil ay pin A3
- And a ground on a black/white wire at pin B1
[IMG]file:///C:/Users/Bryan/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg[/IMG]
Engine: 3.1
Thank you for your input, but my car doesn't have VATS on it. I've been using a key I think the last owner made at Walmart, no resistor in it, and no warnings on the windows which most all VATS cars have. I found out over the past week that it is rediculously easy to break into these cars as well..... locked my keys inside and the person who has my spare set hasn't given them back to me.
Joiner,
The ignition switch is operated via a long rod running along the steering column on the side opposite from where the key is inserted. (About what would be 10 o'clock. The thicker rod running below it located at 9 o'clock is for the Hi/Lo Headlight switch. ) Most likely the ignition switch has shifted just a bit, or the receiver where the rod attaches has worn over the years to where the switch will only activate completely when the distance is shortened by the tilting of the wheel.
J...
J...
