91 camaro stock alarm system
Old Jan 28, 2009 | 06:53 PM
venom204's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Im my car ive got the security light that comes on for a sec on the dash when started. Just below the light ****, i think there was a security light? First owner replaced it with a switch. When i was behind the cover i seen a few wires cut off back there and was wondering if those were for the system. My question is does anyone have any info or can point me to where i might find the info on this? Also how did these systems work?
Old Jan 29, 2009 | 09:24 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: 91 camaro stock alarm system
I don't believe that F-bodies came equipped with alarm systems from the factory.
The dash security light is for VATS and as long as it turns off after start, you're good.
The extra cut wiring in the dash is probably just another hackjob by previous owners. If you want to remove it, make sure you remove only dead/disconnected wires.
Lou
Old Jan 29, 2009 | 10:44 AM
JPhillis's Avatar
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
If my memory serves me correct that security light is for the VAT system. Than is the id chip that is on your ignition key....
MustangBeater20
Oct 29, 2022 09:20 PM
Grant2k
Jul 10, 2018 04:01 PM
camaro71633
Sep 1, 2015 10:24 AM
