spedo and tach not working ?
Old Jan 31, 2009 | 09:09 AM
zombiereaper205's Avatar
i hope im posting this in the right place. well as stated in the title my spedo and tach dont work and i replaced the gauges so i know its not that but im am ordering a new vss, so you think that would fix both problems or just the spedo and if not what are my options ?
Old Feb 1, 2009 | 03:09 PM
tradeforcash@be's Avatar
Car: 1964 GMC Fleetside
Axle/Gears: 3.08
Re: spedo and tach not working ?
Did you check your VSS? I am having somewhat the same problem. My tach waorks though, that is just run off the distributor....Have you checked your wiring?
Old Feb 1, 2009 | 03:21 PM
oh really? well doyou know what color wire or wires they are ?
Old Feb 1, 2009 | 04:07 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Indicating year, make and model of your car is helpful. For example, 82-89 Camaros have cable-driven speedos, 90-92 electronic. Firebirds were cable from 82-85 or so, 86+ electric.
JamesC
Old Feb 1, 2009 | 04:17 PM
well i have a 91 camaro rs
Old Feb 1, 2009 | 04:21 PM
Axle/Gears: 3.08
Check the bottom of your distributor, and see if the plugs are loose, that is where you get the signal for your tach from.....
The signal for your speedo comes from your ECM...not sure yet how to check that without a handheld scanner....
Old Feb 1, 2009 | 04:58 PM
JamesC's Avatar
The most common problem for the speedo seems to be the VSS. Check the tail shaft of the trans for it. A search will provide other possibilties.
JamesC
Old Feb 11, 2009 | 12:32 PM
well I'm back with an update on my spedo and tach, both still not working but now that i changed the vvs my odometer started to work(wierd) but still no spedo is that a sigh that my gage is dead or is it somthing else ? still havent figured out about the tach i checked the wiring and se nothing loose so yea im out on a limb here.
Old Feb 15, 2009 | 11:03 AM
anyone have any ideas ?
eightsixseven
Dec 16, 2024 01:50 PM
Jeremys87
Jul 14, 2022 09:08 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
