parking/ head light question
Old Feb 1, 2009 | 01:06 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
im new on here but had my bird a couple months.
alright well once in a while when i hit the parking lights the lights don't pop up.
which i prefer. but most of the time i hit parking lights and the head lights pop up.
which way is it suppose to go and im thinking about putting a switch for the lights to pop up.
any help?
thanks
Old Feb 2, 2009 | 10:41 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: parking/ head light question
That sure sounds like a problem in the headlight control module. It controls the motors based on what position your headlight switch is in.
If you have a friend close by with the same year Firebird (must be 90+), you can swap the control module to see if the problem switches cars. That will give you a better idea what's wrong.
Hope this helps.
Lou
Old Feb 2, 2009 | 02:58 PM
Blown 346's Avatar
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
I agree, sounds like the switch is going bad. The headlights shouldnt pop up with only the parking lights on.
Old Feb 2, 2009 | 05:44 PM
Car: 90 formula
Transmission: auto
alright thanks guys.
the only friend i have with a car like mine has a 92 bird.
just switched the distributor today. does it use the same control module as on the dizzy?
Frozer!!!
Jan 19, 2024 04:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
