speedometer problems
Car: 92 Camaro RS
Engine: 383 650HP
Transmission: TH 350
Axle/Gears: Posi Ford 9" 4.11
I have a 92 rs with the 3.1 v6. Everything works on the car, one day i started it and let it idle so I can caould check the tranny fluid. It was running for about 20 min. so it was warmed up, i noticed a check engine light on but the motor was still running smooth. When i shut it off and turned it back on there was no check engine light. I took it for a drive and the speedometer was not working at all. I dont know if the VSS just quit on me or what?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
If you have cruise control you can use that to verify the VSS.
Happy Racing!
If People Drove Any Slower They’d Be Going BackwardsHow bout those dorks too scared to drive without headlights in the daytime!
Car: 92 Camaro RS
Engine: 383 650HP
Re: speedometer problems
i dont have cruise control.
also my tail lights,hazards, and running lights didnt work because there wasnt a fuse in the slot. i put a new one in and all my lights work thats when the speedometer quit working
Transmission: 765R4
The econo way:
You can hookup leads to the VSS and monitor it with an audio amplifier.
Or
You can invest in a scanner and verify operation a TON easier.
Happy Racing!
Car: 92 Camaro RS
Engine: 383 650HP
i have access to a real nice snap-on scan tool.
even though the check engine light went off would the code still be stored in the ecm?
Transmission: 765R4
Just scan for codes, if the VSS failed it will read CODE 24.
If the VSS is good along with the associated electronics the scanner will show MPH.
Then you will know it’s the speedometer or its connection that has the problem.
Happy Racing!
Car: 92 Camaro RS
Engine: 383 650HP
thanks for all the help, i'll try it 2moro, the plug in the for the scan tool is right on the bottom of the dassh right, i have what looks like an OBD 2 there just making sure
Transmission: 765R4
You have an OBD1
Happy Racing!
GeneralIesrussi
Sep 3, 2015 03:23 AM
