Backup lights stay on
Old Feb 10, 2009 | 12:29 PM
magadith's Avatar
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
...and its not the switch. I disconnect the wires to the switch and the lights are still on. Where and whats should I try to troubleshoot next?
Old Feb 10, 2009 | 07:40 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Backup lights stay on
Sure you got the right switch? A real steep fine in these parts for having white lights on the rear of a vehicle. Take out the bulbs if nothing else.
Old Feb 10, 2009 | 11:12 PM
magadith's Avatar
Engine: 305 4bbl
The switch is only 5 years old and it worked fine ever since. I had to replace it then because I had no back up lights. But with the switch disconnected, there should be no lights. I can't figure out when the car is on, they stay on.
Old Mar 7, 2009 | 10:47 AM
magadith's Avatar
Engine: 305 4bbl
bump
Old Mar 7, 2009 | 10:51 AM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
first make sure its the right switch. the only thing it really could be is the switch sticking. or possibly the wiring is shorting/touching another hot wire.
Old Mar 8, 2009 | 05:58 PM
magadith's Avatar
Engine: 305 4bbl
The switched worked fine before. Even when I disconnected it from the switch the lights are still on.
Old Mar 9, 2009 | 09:23 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
What are the wire colors on your switch?
Do you have a test light or a voltmeter?
Lou
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
articwhiteZ
Aug 7, 2015 02:25 PM
