63 or 78 amp
Old Feb 13, 2009 | 05:58 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
63 or 78 amp
Which amp will I need if I am building up more of a street/strip car? I will be running a pair of spal fans, holley black pump, keep power window and locks, headlights and a basic radio with no amps etc etc. No air conditioning or even a fan will be under the hood, no defrost or cruise either. The 63 is more then half less but if it won't keep everything charged I'll need the larger 78.
Old Feb 14, 2009 | 11:03 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 63 or 78 amp
The 63 amp will do the job if it is in good working
order-older delco "si"type alternators can have trouble
with bad connections where the 3 stator wires connect
to the output rectifier in the alternator,the crimped on
terminals can work loose,heat up and oxidize-soldering
these will eliminate the potential problem.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
