1986 trans am popup headlights fail to move
Old Feb 14, 2009 | 02:37 PM
tonycastronovo's Avatar
My 86 TA has a 350 chevrolet engine as it used to be a race car and I have since brought it back to original except for engine. The head lights used to popup fine but now they don't. They light and work fine but no movement. Where can I get a wiring diagram showing how they should be wired. Both are not working so I'm assuming it's electrical and not the motors because both worked fine until a week ago. This is the 3-wire system, not 2-wire as in 1989. Thanks
Old Feb 14, 2009 | 03:00 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: 1986 trans am popup headlights fail to move
The wiring diagram would be in the 1986 Firebird Service Manual. Available at www.helminc.com. If you plan on keeping the car and working on it yourself, you need to buy the book.
Sorry, I forgot to add that I include the headlight diagnostic guide along with the instruction sheet with the TDS 508210 1982-86 headlight repair kit I sell.
Lon
Old Feb 15, 2009 | 08:10 AM
Lon
Lon: I am selling the car. How much for just the headlight wiring schematic so I can try to trace the problem down. It must be a relay or electrical because the odds of both motors going out at the same time seems improbable. Appreciate all the help. Tony 321-848-2451
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
