Detection!!!!
Old Feb 14, 2009 | 07:53 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Detection!!!!
Anyone know of a good cheap laser detector? one that actually will work,lol..
Old Feb 14, 2009 | 08:03 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Detection!!!!
don't speed.
Old Feb 14, 2009 | 08:38 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Detection!!!!
how about i do and just get a detector, thanks :P anyone else going to answer my question properly instead of diverting from my question?
Old Feb 14, 2009 | 08:40 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
Re: Detection!!!!
Originally Posted by toxik IROC
don't speed.
lmfao ... um get the one i have lol it picks up the cop like a mile away i got it at autozone for like 50 bux then it went up to 80 then i havent seen them since its also got to blue LEDs that go off when it picks a cop or something else up i love it...
Old Feb 14, 2009 | 09:07 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Detection!!!!
Get a valentine one detector http://www.valentine1.com/ their not cheap, but people swear by them. I was planning on getting one ,but then I realized I need weatherstripping more than a detector.
Old Feb 15, 2009 | 09:08 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Detection!!!!
the laser guns the cops use on the side streets of most cities only tunr on when the cop points at a vehicle and pulls the trigger so buy the time your detector goes off your detector goes off your done on the highway not to sure it might be on all the time
Old Feb 15, 2009 | 09:11 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Detection!!!!
yeah thats what i thought, it was kind odd i'll ask a few of my cop buddies i know at work :P
Old Feb 15, 2009 | 10:52 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: Detection!!!!
You need a laser jammer if the cops are using laser guns in your area. A good radar/laser detector like the V1 will detect laser, but most of the time it will only be after the cop has acquired your speed. If you want to do some research, go to radardetector.net. They have a boatload of info on radar detectors and laser jammers.
I have the V1 in my car and has saved me countless times from getting pulled over. The cops don't use laser much, so I don't have the need for a jammer yet. Also, don't ask your cop friends about detectors/jammers, since they will probably just say that they don't work.
Old Feb 15, 2009 | 02:30 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: Detection!!!!
CB radio
I went on a trip to GA and my buddy had one in his car and it saved us from more cops than the detector did. I plan on putting one in my car soon because alot of people still use them and they report cop locations way before a detector can.
Old Feb 15, 2009 | 02:35 PM
Car: 1991 Trans Am
Axle/Gears: Stock
Re: Detection!!!!
the radar detector i have is a 360* view so it picks up in front and behind me i have had it for a year now and has saved me alot
Old Feb 15, 2009 | 02:57 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Detection!!!!
my cop buddy is cool, don't worry, we talk about how the dept got the charger and how he loves speeding with it for no reason lol
Old Mar 3, 2009 | 12:13 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Re: Detection!!!!
Do they still make in-dash type detectors? Or all of them the kind that you mount on top of the dash?
That may be a dumb question, I was curious
Old Dec 9, 2010 | 03:24 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Re: Detection!!!!
yes i know it is an older thread.
don't waste your money on a "laser detector".
LIDAR will send a burst of IR light in the nanosecond range and pick the signal back up in less than 50 milliseconds.
Another words, by the time your laser detector goes off, the gun already has your speed, and your getting a ticket.
As for laser jammers, they do work, provided that they operate in the correct spectrum. The best way to do this to work for all guns, is to have 2 separate IR banks, with 2 different MHz ranges, throwing IR "pollution" so that the LIDAR gun cant pick out its own signal to give the operator the speed of the vehicle being tagged.
I am currently building a prototype jammer for LIDAR, which there are no laws against having in the state of florida, being that the LIDAR gun is still relatively new, and there haven't been any regulations set up yet.
If you do run a LIDAR jammer, do be prepared to be pulled over 50% of the time, because they couldn't get an accurate reading or couldn't get a reading at all. In this case, hope your jammer is well hidden and play stupid.
Old Dec 10, 2010 | 08:38 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Re: Detection!!!!
You're doing it wrong. If an officer hits you with laser, you only need to jam the signal as long as it takes you to slow down to a reasonable speed. Then you turn off the jammer immediately so the officer will record a speed. This way there is no suspicion of having a jamming device.
Old Dec 10, 2010 | 05:59 PM
willexoIX's Avatar
Re: Detection!!!!
This may be the case, but it can be done either way. Besides, in the 3-6 MHz range, it can only operate for about 4 seconds before it will burn out you IR banks.
I just like seeing the puzzled look on the cops face
Elephantismo
Feb 13, 2019 12:51 AM
Caspar
Jun 19, 2016 11:19 PM
BWilcox
Sep 20, 2015 12:19 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Grim Reaper
30
Mar 31, 2003 03:12 PM
