water temp guage hook up?
Old Feb 16, 2009 | 03:16 PM
BlackBird84's Avatar
Car: 89 GTA
Engine: 5.7 350 TPI (L98)
Transmission: Stock GTA Trans
Where does it hook up too intake? head? water neck?
and also where does the wire that connects to it come from? I cant find it
Old Feb 16, 2009 | 03:44 PM
50bmgshooter's Avatar
Re: water temp guage hook up?
on the pass side head right by cylinder # 6
Old Feb 16, 2009 | 03:49 PM
Car: 89 GTA
How can I test if the gauge is working? My engines always ran on the cool side and takes alot of time to warm up thats why I don't want to test by idling it. My radiator fans are not kicking on thats why my concern is the temp I think the fans are worn out the battery polarity's were reversed shorted out my icm and ecm so I replaced those and everything else seems to work inside.
Old Feb 16, 2009 | 06:47 PM
Car: 89 GTA
Got it now thanks
Old Feb 17, 2009 | 10:21 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
That's the temperature switch for the fans, NOT the gauge.
The gauge sensor is in the driver side head, between the first two spark plugs. Same spot in the head, but different head.
You can troubleshoot the gauge by disconnecting the green wire and verifying that the gauge reads full cold, then shorting the wire to ground and verifying that the gauge reads full hot.
Hope this helps.
Lou
Old Feb 17, 2009 | 08:58 PM
AKATDOG's Avatar
Car: 84 Z28
Hope this helps.
Lou
so if you run a ground wire to the green wire on the temp gauge it should read full hot ?
Old Feb 18, 2009 | 08:57 AM
BigBadLou's Avatar
Engine: TPI
That's exactly right.
junior419
Apr 7, 2025 11:35 AM
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
codeysabatini
Sep 20, 2015 11:36 AM
gta892000
Sep 16, 2015 12:37 AM
