Checking engine light with out reader?
Old Feb 20, 2009 | 06:23 PM
BlackBird84's Avatar
Car: 89 GTA
Engine: 5.7 350 TPI (L98)
Transmission: Stock GTA Trans
Is this possible? How do i set it up? I have all the codes just need to know what code my GTA is putting out. engine light doesn't come on at cold start up but comes on when its warmed up for about 5 minutes of idle.
Old Feb 21, 2009 | 03:49 PM
mfaust's Avatar
Car: 88' Trans-AM WS6
Re: Checking engine light with out reader?
you have a test port below the steering wheel, on the lower dash.
It caled the ALDL Terminal, (with the car off) you need to jumper terminal "B" to Terminal "A"
If there is a code stored it will flash the code in a sequence like 1 flash pause 2 flashes, which would be code 12
Old Feb 21, 2009 | 04:00 PM
mfaust's Avatar
aldl terminal pinout is
F | E | D | C | B | A |
__________________
G | H | J | K | L |M |
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
