cs144 alternator conversion ?
Old Feb 22, 2009 | 10:10 PM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Hi guys, I am in the process of converting a cs130 alternator to cs144. I have read that you need a resistor in the "switch on" wire, terminal L . I also read that these alternators use the same voltage regulators. So my question is will I need this resistor for my conversion? Car is 1988 camaro,TBI engine. By the way, alternator is off of a 1993 cadillac fleetwood, the connector has two wires, camaro connector has three wires. Does the third wire take care of this? Also camaro has volt meter , caddy does not. Thanks in advance, Dean!
Linson
Oct 24, 2025 02:00 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
