amps to the window motor, trunk relase and rear defroster
Old Feb 25, 2009 | 06:31 PM
fcukit33's Avatar
Car: 92 camaro rs
Engine: 305tbi
i want to put togel switchs in for my windows, trunk relase and rear difroster...any body know how many amps the switch need to be i only found 10s and 30s in the autozone by me..thanx
Old Feb 25, 2009 | 09:28 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: amps to the window motor, trunk relase and rear defroster
your best bet to look how many amp fuse was protecting the circuit. the winows the 30 will do. and depending on if you are powering the hatch release itself or the relay will be the deciding factor. the rear defrost you should be able to skate on a 10, i know in most cars there is a relay for the defrost so if someone knows for sure chime in
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
