power window problem
Old Feb 28, 2009 | 06:31 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
i had removed and reinstalled the interior on the 88 iroc vert. prior to this the windows worked. the ground is secure and wiring looks good. using a test light, i get power to the fuse box with the ingnition on. i changed the fuses and still nothing. the orange power wire from the back of the fuse box goes to the block mounted to the inside driver wall. i know the pink wire supplies power, black is ground, and the other four go out to the doors.
there was only the orange wire from the fuse box for the windows. im not sure if something fell out or came disconnected. ive got an 85 shop manual but im still convused. any ideas?
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 13, 2015 12:59 PM
