Rear hatchback won't close (Electric)
Old Mar 13, 2009 | 01:11 AM
Blud_Shot_Eyez's Avatar
Car: A few camaros
Engine: V6, 305 TBI, 350 TPI
Axle/Gears: 2.77
Need help figuring this out, where should I start? Lost power, it used to close by itself now it wont close at all!
Old Mar 14, 2009 | 01:38 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Rear hatchback won't close (Electric)
Pull off the rear surround trim panel. Unplug the blue wire from the red/white stripe wire. Use a multi-meter or test light and check that you have 12 volts at the red/white stripe wire. While your at it grab hold of the latch and see if you get motion side-to-side or front-to-back. That would indicate bad guides. Check that the clear plastic motor housing isn't cracked. These, along with all the other items you may need to repair your pull-down unit are available on my web site.
You didn't post the year and model of your F-body. The fuse for the camaro pull-down unit is in the fuse panel. The fuse for the firebird pull-down unit is in a separate single fuse holder that should be attached to the outside of the fuse panel. It can be slid off of the fuse panel, so if it isn't attached to it you'll have to search for it.
Lon Salgren
Old Mar 14, 2009 | 02:32 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
lonsal has the right idea, but you can also take a large flat head screwdriver and push down on the locking mech inside of the lower latch to see if it goes down. sometimes they lock as if the hatch was down, so when you drop it you hit the closed latch instead of an open one.
does it click when you hit the inside open button? if it does you are getting power to it. if you can push it down and it moved by itself they you are getting power to the self closing latch.
you could be out of allignment.
if none of those things happen - start looking for a power failure.
Old Mar 14, 2009 | 02:18 PM
lonsal's Avatar
That reminds me. As Tony may be referring to, the pull-down unit may have gone down only part way and needs to be re-set. You re-set it by pressing and holding down the striker-sensing switch. It is a small black paddle located in front of the latch. The pull-down unit ONLY powers down if that switch is being depressed. If the pull-down unit started down and you popped the hatch open before it reached the end of the Down cycle the pull-down unit will be stuck mid-cycle and will not power down again until that switch is again pressed and held down.
Lon Salgren
Old Mar 14, 2009 | 03:08 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Check the fuse box for a blown fuse.
Old Mar 14, 2009 | 10:21 PM
Car: A few camaros
Axle/Gears: 2.77
Lon Salgren
Thanks for the help everyone, it was just a switch that needed to be reset!
MustangBeater20
Oct 29, 2022 09:20 PM
customblackbird
Aug 15, 2021 10:16 PM
colton_carlson
Mar 8, 2019 12:21 PM
E Rod
Aug 28, 2015 05:17 AM
hectre13
Aug 26, 2015 08:17 AM
