code 36 question
Old Mar 15, 2009 | 09:32 PM
black and blue's Avatar
Car: 87 iroc
Engine: 383 forged tpi w/maf
Transmission: 700r4/3200stall
Axle/Gears: moser 9 bolt 389
code 36 question
hello and thank you, i have a 350 tpi motor with a stealth ram and i am getting code 36 wich as i read it is intake air temp sensor so i replaced it erased code started it and it came back, so i then test voltage to it which is a constant 5 volt and from what i have read on searches is correct. i then cheched ohms on both sensors at room temp and they are showing coreeectly, so my question is what else could shoot this code? also i did disconect throdddle body coolant on the install but if that will effect it so be it i just wanted to provide as much info as possible to not waste any ones time
chazman
Aug 28, 2018 03:25 PM
CORV3TT3
Aug 23, 2015 11:26 AM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
