Identify this wiring harness
Old Mar 16, 2009 | 06:53 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
1989 350 TPI - Under the hood, attached to the firewall on the passanger side just behind where the distributor plugs into the coil. There are two wires on the female side that run into the large split loom that looks to go to the injectors (and elsewhere). The male end goes down the firewall and I lose it quick. Not many wires out of it either. IIRC the wires on the female side are red and black which to me says hot and ground. The harness is pretty burned out and I had some starting issues this weekend that seemed to be remedied by wiggling the wires in the harness. I want to replace the harness but not sure what its called or where to get it.
It is in this area. I will get close up pics soon...
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
