Brake light harness has no juice???
Old Mar 18, 2009 | 06:06 PM
GM Man's Avatar
Car: 1986 2.8 Camaro
Engine: TPI 350
Transmission: Tremec TKO
In my quest to figure out why my brake lights are stuck on, I checked a few things. The brake light switch is good, but when I checked the brake light harness with my volt meter there was nothing there. When I pull the fuse for the brake lights it does kill the lights, so that kind of confuses me. My question is should there be power to the brake light harness?
Old Mar 18, 2009 | 06:38 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Brake light harness has no juice???
When the brake lights are on,you should have power at the harness for them(the brake switch provides this power)
How did you go about checking the switch?
Is it adjusted correctly? meaning,does the trigger on the switch get depressed when you take your foot off the pedal?
Old Mar 18, 2009 | 09:04 PM
GM Man's Avatar
Engine: TPI 350
I pulled the switch out, and tested it with my volt meter. When it closed the meter rang out a tone.. I have tried to depress the button on the switch and hold it in to simulate the brakes being off, but the lights just stay on, no matter what I do..
Vintageracer
Jan 10, 2020 05:33 PM
TheJoeY88
Dec 31, 2016 07:30 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
