Fuel problem
Old Mar 20, 2009 | 08:54 PM
boost d3vil's Avatar
Fuel problem
Hello guys I just recently bought a 1990 camaro iroc and it seems to have a fuel problem.
I've tested the pump and it runs fine but there doesn't seem to be any power going to the relay SOME of the time. I don't know, it only works when it wants to I guess.
There's an aftermarket MSD ignition system wired in by the distributor and there is a jungle of wires over there. My only guess is there's a loose connection somewhere or bad ground I dunno it seems when I move some wires around some it works for a bit then later on goes back to not sending power the relay. From what I've done so far I haven't been able to find the problem - loose wire or an open circuit somewhere. But when it does work and the relay gets power it'll start right up everytime for about a day or so before it goes all bad again.
Has anyone else encountered something similar?
Old Mar 21, 2009 | 10:46 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Fuel problem
Have you tried this tech article yet?
http://www.austinthirdgen.org/index.php?pid=35
Lou
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
