Rear defrost and trans-shift problem
Old Mar 20, 2009 | 11:03 PM
Hartmann's Avatar
Hello everyone I have an 1986 IROC that has a rear defrost, but no switch. I see several wires in the back, what do I need to connect along with getting a switch to make rear defrost happen? Also I have an auto tranny but the problem is there is no indicator light for which gear I am in, I changed the light bulb but that isn't the problem. How do I fix this? My steering wheel is after market, grant. If has no center horn cap. What would I need to install to get the horn to work? I believe the horn is still in place just no center cap for it.
Erik
Old Mar 27, 2009 | 07:39 PM
Hartmann's Avatar
Re: Rear defrost and trans-shift problem
nump.
Old Mar 27, 2009 | 08:22 PM
IROCKET4U's Avatar
Car: 1988 IROC
Engine: 5.7 litre
Transmission: Auto--700R4
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Most likely your car was a rear defrost delete (so was mine) and someone replaced your rear glass with one from a car which had rear defrost. I found a switch on ebay for $13.00 shipped. You will have to run wires back to your hatch.
http://cgi.ebay.com/ebaymotors/82-89...2em118Q2el1247
On the horn issue have you pulled the wheel to see if the horn switch is still there? If not you would need to buy one of those and the horn wire. I wouldnt think it would interfere with an aftermarket wheel.
It looks something like this (round plastic). I know you can buy them at a dealer for $30. Horn wires on ebay are about $15
http://cgi.ebay.com/ebaymotors/67-68...QQcmdZViewItem
This one is for a 67-69 camaro but they look similar.
Not sure what to tell you on the lightbulb for the tranny. If its not getting power you might have to run another wire from the power window switch.
Old Mar 27, 2009 | 08:55 PM
Hartmann's Avatar
Thanks a bunch bud!
Jorlain
Aug 24, 2022 05:11 PM
customblackbird
Aug 15, 2021 10:16 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
