Code reader. What code is this? Any info please.
Old Mar 22, 2009 | 04:45 PM
STRIKER911's Avatar
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
I can never find stuff when I try to search. Keeps coming up with unrelated posts. So here goes. My car runs OK but something is wrong still. I have the plug in GM code reader that makes the C/E light flash codes. I plugged it in, then turned on the key. Hope that was right. Got the same code. One flash, two flash. Any info on this? Thanks guys.
Old Mar 22, 2009 | 05:32 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Code reader. What code is this? Any info please.
A code 12 means systems ok. Counting the SES light flashes will flash code 12 3 times when you start the diagnostic, then it will flash what codes are stored 3 times each. It will go back to flashing code 12 when all codes have been displayed. Plug in your code reader, turn on the ignition, wait for the SES light to flash code 12(1 flash, pause, 2 flashes) 3 times, then the count the flashes for the codes(ex. 3 flashes, pause, 4 flashes). If it keeps flashing a code 12, then no codes are stored in the ecm.
Old Mar 22, 2009 | 10:19 PM
STRIKER911's Avatar
Car: 89 RS
ok well i waited 3 times this time, & got code 32, or 3 flashes then 2. Let it do its thing twice to make sure thats all. Just the 32. Im about to search on it too. Thanks.
Old Mar 23, 2009 | 10:00 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Well, what car/engine do you have?
Code 32 means "EGR failure" on TPI and I believe also on TBI. There are many troubleshooting articles on that system.
Lou
BumpaD82
Feb 26, 2016 02:57 PM
Jonesyfxr
Sep 26, 2015 02:08 AM
lethaldomestics
Sep 21, 2015 01:18 PM
Reese-J
Sep 14, 2015 02:43 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
