some gauges dont work.
Old Mar 22, 2009 | 12:33 AM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
My cars RPM, water and voltage gauges dont move anymore and was wondering if I can fix that some how. I tried starting the car and battery died and gauges went blank now
Old Mar 22, 2009 | 10:28 AM
Transmission: 700r
Re: some gauges dont work.
bump
Old Mar 22, 2009 | 11:28 AM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
Did you check the gauges fuse?
Old Mar 22, 2009 | 07:48 PM
hachiroku_rs's Avatar
Car: 92 Camaro RS
Engine: 3.1L V6
is it only those gauges, does the dash light up? do they sometimes work? or are they always dead? what do you mean by they went blank, is it a digital dash?
or to be honest what it seems like is that the connector to the back of the dash is loose or not fully plugged in, try tightening the screws on the bottom and top of the dash, or even pushing the connector from the back.
Old Mar 22, 2009 | 08:43 PM
ClickClickVroom's Avatar
Car: 92 Z03 RS TBI
Engine: 5.0 L03
I recently had an issue with my gauges as well. Turns out, my damn negative battery cable had become slightly loose, and the car could fire up, but would sputter out now and then, and the tac didn't work.
Old Mar 23, 2009 | 12:18 AM
Transmission: 700r
Car has a bad gas pump and tried starting it. Battery went very low and water, RPM, and volt gauges all went below a actually reading scale except for RPM which is stuck at 7000 sitting on needle. Lights come up still just the gauges dont work. The gauges all broke when the battery has gone dead or disconnected
Old Mar 23, 2009 | 06:50 AM
Car: 92 Camaro RS
Engine: 3.1L V6
[quote=87IROCZCamro;4090891]Car has a bad gas pump and tried starting it. Battery went very low and water, RPM, and volt gauges all went below a actually reading scale except for RPM which is stuck at 7000 sitting on needle. Lights come up still just the gauges dont work. The gauges all broke when the battery has gone dead or disconnected[/quote
ive been doing some research for you and it seems like theres alot of people who have had this happen to them once there car died, my car had an issue after i swapped the engine, the engine didnt repond well once i floored it, long story short for the rpm gauge, try this, unplug your ecm, and wait 30 secs before you replug it,(i forget the technical name for it but once you do this, it tells the car to go back to its programmed or stock {if you dont have a chip} settings) it sounds like it needs a reset. try this for the rpm gauge, should go back to normal.
for the water and volt gauge do the above first, if it still is not functioning then try replacing the component, just the volt and water temp gauges.
Old Mar 23, 2009 | 10:21 AM
Transmission: 700r
Thanks Ill try that in the next couple days
Bubbajones_ya
Jul 6, 2024 08:32 PM
GTAman
Jul 3, 2024 07:29 PM
customblackbird
Oct 1, 2015 04:30 PM
wisemanz28
Sep 20, 2015 01:26 PM
86IROC112
Sep 11, 2015 04:04 PM
