wiring up my tach
Old Mar 25, 2009 | 09:00 AM
joker0907's Avatar
Car: 1991 camaro rs, 2001 buick century
Engine: 305, 3.1
wiring up my tach
ok i dont know if im getting all the defective tachos or not but im having the worst problem with it. I got it fused with the radio and the wire going into the coil wire that its supose to be and a good ground and nothing no zeroing out or nothing on one of the tachs and the other one just turns on it goes from 0 to 9000 then back to 7k and sits there and doesnt move... ive tried even direct conecting them to batt and the coil and still nothing am i doing something wrong or just getting all the defective tachs...
Old Mar 25, 2009 | 10:42 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
What tach did you get?
Brand, model number.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Keep em turned off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old Mar 25, 2009 | 10:55 AM
joker0907's Avatar
Engine: 305, 3.1
Re: wiring up my tach
well the first one i tried was a sunpro with the shift light on it the other one was just a cheapo from auto zone without a light
Old Mar 25, 2009 | 11:19 AM
NINÅ's Avatar
Transmission: 765R4
The odds of having purchased two separate defective tachs is about zero.
Without the model number we cannot provide exact details.
However many tachs have a:
GROUND
ILLUMINATION TERMINAL
TACH TERMINAL
12 VOLTS IN TERMINAL
We suggest you have a friend give you some in person assistance.
Also, you might want to buy one from a speed shop.
It might cost more, but there are people there that “turn the wrenches” and should be able to point out what wires go where.
You don’t want to hook it up wrong because you might damage it.
Happy Racing!
Old Mar 25, 2009 | 12:01 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Some tachs require you to use the GM filter that should be hidden in your dash.
Old Mar 25, 2009 | 12:09 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
my filter was mounted on the firewall behind the distributor.
Old Mar 25, 2009 | 12:15 PM
joker0907's Avatar
Engine: 305, 3.1
i turn wrenches... and i have hooked tachs up before but i have tried 2 camaros now a 89 and 91 and both do not seem to work for some reason so i called in my friend that works at a restoration shop and he said its all wired correctly and he believes that i actually recieved 2 defective tachs....
Old Mar 25, 2009 | 12:16 PM
joker0907's Avatar
Engine: 305, 3.1
the filter thing i did not know about can you explain more about the filter?
Old Mar 25, 2009 | 12:36 PM
NINÅ's Avatar
Transmission: 765R4
Re: Filter.
As long as you hooked up the wire the used to go the original tach you are using the appropriate wire.
You want a direct feed from the TACH TERM which originates near the distributor.
Happy Racing!
Old Mar 25, 2009 | 03:06 PM
joker0907's Avatar
Engine: 305, 3.1
ya i have that i really dont know whats up im going to buy another tach and figure out if that one works.
Old Mar 25, 2009 | 03:20 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
i hooked mine up to the radio fuse, a ground to the firewall, and the wire on the "tach" part of the distributer and mine works fine. i have a "equus" from o'reillys. its a 3 3/8 in dash tach. it cost 70 bucks.
Old Mar 25, 2009 | 04:13 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Every tach I`ve wired up on my camaro or chevy truck has had ground,power wire for light and a wire that connects to the tach lead at the coil.Pretty simple and I`m no mechanic.Ive never needed a filter.
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 7, 2015 04:49 AM
