steering column / ignition help needed.
Old Mar 27, 2009 | 11:35 AM
Miles87Z28's Avatar
Car: 05 Pontiac Sunfire, 87 Z28
Engine: 2.2 Ecotec, 350 TPI
Transmission: Auto, 700r4 with shift kit
Axle/Gears: No clue, limited slip.
Alright guys finally got a new (used) column out of an 87 camaro, cool even same year as mine. Well i just got done taking my old one out and everything on the two is alike except for on the column that was is my car a cable hooked to the back of the ignition switch. I have no clue what this was for. If its a cruise thing i don't care since these cars are made to be driven and not put on cruise control. Also the column i bought has a lever under the key that must be pussed down in order to fully turn off the ignition, Why Is This And whta Does It Do. any input is greatly appreciated.
Old Mar 27, 2009 | 11:57 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: steering column / ignition help needed.
Sounds like one car had a stick, the other an automatic.
Old Mar 27, 2009 | 12:39 PM
Miles87Z28's Avatar
right thats what i thought it was. Now will my car (The Automatic) run with the column from the stick shift without that cable hooked up and if not can i go to the autoparts and by a switch for an automatic and put it on the column from the stick shift??? Or am i just S.O.L.
Old Mar 27, 2009 | 01:28 PM
attica0's Avatar
Car: 83' S-10, 91' Camaro RS
Engine: 305, 305
Transmission: 700R4 in both
they sell switches at the auto parts store i just bought one the other day
Old Mar 27, 2009 | 01:34 PM
Miles87Z28's Avatar
But can the automatic ignition switch work with the steering column from the stick shift??? Do i even need to replace it, will the car start & run without the cable hooked up
Old Mar 27, 2009 | 02:25 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The cable goes to the shifter, to keep you from locking the steering wheel unless the trans is in park.
Old Mar 27, 2009 | 04:05 PM
Miles87Z28's Avatar
Ok. So will the car run and drive without the cable hooked to ignition. The column itself doesn't lock don't know what happened there.
Nick McCardle
Sep 10, 2015 08:36 PM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
