codes 22, 33 and 43. will start but usually die right after
Old Mar 29, 2009 | 03:14 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
i have a 91 z28. it sat for about 3 yrs. I pulled to 305 out and installed a 350. i used the tpi from the 305 on the 350. i have been theough he** and back with this car. I have a code 22, 33 and 43. the car will start but it dies immedatly most of the time. if i bearly hold the throttle down it will idle for a little longer but it always dies. I have not changed the TPS sensor or MAP sensor. I want to know before i spend the money on the 2 sensors, if they would be the cause of the car dying? or could i have a bad ecu? Also could the smaller injectors and ecu for a 305 cause this problem? All i changed was the 305 to 350 block pretty much. the top of the motor and everything else was originally in the car with the 305.
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Andrew6.688
Dec 13, 2015 10:59 AM
EFR2000
Aug 18, 2015 08:54 PM
