Fuel Pump Relay switched 12V Source Wire, Which One?
Old Mar 29, 2009 | 11:13 PM
The_Phoenix's Avatar
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Hows it going? I've searched around this board and found very little info regarding the 12V switched wire on the fuel pump relay for an '89 GTA NTM I don't have a multimeter. The colors for the fuel pump relay wires mentioned in other threads I read didn't match mine at all. I'm in the process of installing a 4-wire o2 sensor on my car and would like to know which of the following wires on my fuel pump relay are 12V switched: Orange (large diameter), Orange (smaller diameter), Green/White, Black/White, Tan/White. Any info is appreciated.
Thanks,
Phoenix
Old Mar 31, 2009 | 10:05 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
FUELING AROUND
Your colors don’t match mine either.
On mine it’s grey.
You don’t have a test meter so use a light bulb, such as a spare marker light to probe for your switched wire.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Keep em turned off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old Mar 31, 2009 | 08:38 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: FUELING AROUND
It's the tan/white. But don't use it for the O2 power, it's not the right place to tap into. I'd go from ignition or another wire.
Nina, your wire is grey because you likely have a newer year harness. Yeah, good o' Cheby, they could not make up their mind even on wire colors.
Lou
Old Apr 1, 2009 | 02:09 AM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Re: Fuel Pump Relay switched 12V Source Wire, Which One?
On mine it’s grey.
Happy Racing!
Yeah another guy on this board installed a 4-wire o2 sensor as well and his 12V switched wire was grey as well; his is a '92 GTA btw. Thanks for the tip on the test light NINA I'll try that out tomorrow.
Lou
So I shouldn't tap into any of the MAF power, Fuel Pump or MAF burn-off relays? Installing it via ignition would mean running it through the firewall into the fuseblock correct? Thanks for the information Lou. If only GM knew that using the same wire colors would make our lives alot easier .
Phoenix
Old Apr 2, 2009 | 12:13 AM
BigBadLou's Avatar
Engine: TPI
The FP and MAF are powered from the 20A inline fuse by the battery which is already maxed out.
If the O2 sensor heating element requires only an amp or two, it shouldn't be a big deal. Knowing O2 sensors, however, I am afraid it's a little more current than that.
You could tap into the brown wire that goes to the alternator, it powers the fan relays and the alternator excitation field so it has some spare "room".
Hope this helps.
Lou
Old Apr 2, 2009 | 11:57 PM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
I see. All of the information I researched regarding the installation of 3-wire and 4-wire o2 sensors, always suggested tapping off of the f/p or MAF switched 12V wire. Would tapping off of those relay wires burn out the sensor? I never thought of that but it makes sense and I think that it will kill the sensor. I'll tap into the brown alternator wire instead. Thanks for clearing that up Lou. Since we're on the subject, is it true that the 2 ground wires on 4-wire sensors have to be installed seperately? I appreciate the information.
Thanks,
Phoenix
Old Apr 3, 2009 | 09:30 AM
BigBadLou's Avatar
Engine: TPI
As for the grounds, the 3-wire sensor is grounded through the exhaust so obviously it doesn't matter where the ground comes from.
Good ECMs run a separate ground from the ECM case to each sensor, though.
Lou
Old Apr 3, 2009 | 10:59 PM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Lou
Makes sense . I'll be installing my o2 sensor tomorrow and let you know how it goes. Thanks again for the information Lou.
Phoenix
Old Apr 4, 2009 | 11:59 PM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
I removed my old 1-wire o2 sensor today and it looked like its never been changed before. It was completey covered in soot, as well as there were deposits on the inside of the fins on the tip of the sensor. My 4-wire sensor and pigtail are actually not long enough to reach the fuel or MAF relay wires but I'm not however thanks to BigBabyLou, I was recommended to tap off the brown alternator wire for "key-on only" operation. The sensor's wires are near that particular alternator wire btw. I'm going to use a wire tap made by 3M such as this one:
to tap into the wire. In my case all I would do is slip each wire side-by- side into the openings you see there and crimp that grooved metal piece down with pliers. As you do that, the metal piece digs (cuts) through the wire's plastic sleeve contacting the bare wire only in between each groove. This provides a connection beteween the 2 wires. Pretty cool little trinket if you ask me . I'll post my results.
Later,
Phoenix
Old Apr 5, 2009 | 10:42 PM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Installation is done. I noticed the car now heats up in about 2-3 min. as well as run smoother. I used the 3M wire tap to tap the pigtail's 12V switched wire into the tan/white wire from my alternator. I then twisted both remaining grounds together and crimped on a ring terminal to slip into the ground bolt on the back of the driver's side head. Plugged in the o2 and ecm signal connectors and called it a day. Once again thanks very much for your input Lou it was a big help.
Later,
Phoenix
RazorN8
Jan 7, 2022 11:44 AM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
apie2546
Aug 8, 2015 07:12 AM
