MAF sensor wire??!!?
Old Apr 1, 2009 | 08:37 AM
zakks92maro's Avatar
ive got a 92 z28 with 350 tpi. i know the MAF sensor is between the throttle body and the air filter, but there are no wires connecting the MAF snesor to anything. i cant seem to find them though. am i just missing the wire completely or does it have a secret location somewhere i dont know about???
Old Apr 1, 2009 | 11:45 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: MAF sensor wire??!!?
If you got the original 90+ TPI setup, it doesn't use a MAF sensor. They used it only on the TPI systems until '89.
Hope this helps.
Lou
Old Apr 1, 2009 | 11:50 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
you HAVE A MAP - mass air pressure - you don't have a MAF - mass air flow. the maf requires air to pass over the wire to tell the computer how to react and what is happening.
your map uses air pressure in the manifold to tell the computer what is happening and how to react.
but you are right about the location, if you had a maf.
Old Apr 2, 2009 | 11:35 AM
i know its not the original engine, it might have been a 305 TPI consideringit was a z28, but idk if its the right wiring harness or computer. i dont know much about the electronic ****! STICK TO CARBS!!!!!!
Old May 17, 2009 | 06:57 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Is there any way to improve/clean up the MAP sensor like you can with the MAF?
Old May 17, 2009 | 11:42 PM
BigBadLou's Avatar
Engine: TPI
Nope. The MAP provides pressure readings to the computer so that it can adjust the engine fueling and timing. There is nothing that can be improved on this simple sensor.
Lou
Old May 18, 2009 | 08:34 PM
Mr Froman's Avatar
Alright, thanks for the reply.
Caspar
Jun 19, 2016 11:19 PM
Logan Bryant
Aug 27, 2015 11:52 AM
nuggie
Aug 25, 2015 01:27 PM
Bert87
Aug 23, 2015 03:50 PM
perZ
Aug 21, 2015 05:51 PM
