electric hatch unit stuck down, hatch open: HELP
Old Apr 1, 2009 | 06:26 PM
Mailbox Hunter's Avatar
Car: 89 Camaro RS
Engine: 350 TBI
Axle/Gears: 10 bolt/ 3.23 Gear.
For one reason for another, the hatch motor retracted down into the back. I don't know how to get it back up so i can close my hatch again. Anyone know whats wrong?
Old Apr 1, 2009 | 07:04 PM
aldaran's Avatar
Re: electric hatch unit stuck down, hatch open: HELP
Mine did the same thing sometime back. I could not get it to close, but my hatch was stuck in the up position. I finally ordered this kit and it started to work again.
http://www.top-downsolutions.com/pop...027f1a8ca40560
You pretty much rebuild the hatch unit. Did you try the key and see if it would trigger it to go back up?
Old Apr 1, 2009 | 07:39 PM
hotrod16105's Avatar
Car: 1988 Firebird Formula 350
Axle/Gears: BW 3.27
There is a micro switch on the latch where it grabs the striker. If you use a screw driver to push the switch down and turn the key at the same time it should come back up unless there is an electrical problem. Happened to me a few times while working on the rear of my car.
Old Apr 1, 2009 | 07:43 PM
Car: 89 Camaro RS
Engine: 350 TBI
got it!
i just kept slamming the lid down into the unit until it clicked closed,
hit the switch and it came right back up.
i guess with enough force anything possible.
Old Apr 1, 2009 | 07:57 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Originally Posted by Mailbox Hunter
got it!
Good way to destroy the hatch motor assembly. Forget the screw driver and just use your finger like you knew what it was for and tigger the switch.
Old Apr 1, 2009 | 11:21 PM
aldaran's Avatar
That's correct. The housing easily cracks and will cause more problems later on. The kit above has a new housing with metal to reinforce to prevent cracking. My hatch unit works like new with it.
Old Apr 3, 2009 | 02:20 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes, don't slam the hatch closed. Just reach in and press on the striker-sensing switch. When the motor finishes going down you'll hear a CLICK which is the reversing switch being tripped. Release the striker-sensing switch and it should power all the way back up.
You can buy the replacement parts for the pull-down unit from TDS (Top-Down Solutions) including the reinforced motor housing to replace the one you broke by slamming the hatch shut.
Lon
Bubbajones_ya
Jul 6, 2024 08:32 PM
punkmaster98
Sep 30, 2015 11:01 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
scottmoyer
Sep 7, 2015 07:06 PM
Glowsock
Sep 5, 2015 07:48 PM
