location of fuel injector ground???
Old Apr 6, 2009 | 02:48 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I want to test my injectors as part of a flooding issue. I can't seem to locate the ground to test for ohms. Where and What am I looking for? (I did do a 'Search') Thanx, Nitro-Nicky
Old Apr 6, 2009 | 04:43 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: location of fuel injector ground???
One side of the fuel injector is wired to a fused hot source. The other is hooked directly to the ECM, which switches ground to activate the injectors.
To test the injector, take the connector off and test the resistance between the two terminals directly on the injector.
Old Apr 7, 2009 | 08:07 AM
neagan's Avatar
Thanks for the info prompt. These are new balanced 24#'ers and apparently if I want to see if they are staying on to long (for the over rich fuel condition) in the duty cycle, I'll need to verify the resistance at the fuel rail. Apparently the ECM fires a bank of 4 injectors each cycle and all 8 plugs of mine have little pools of raw fuel in them. Additionally, I'm not having much success in prompting my ALDL cable connection to check on the issue with a scanner. Nitro-Nicky
Old Apr 7, 2009 | 03:17 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
24s in a 350 are fine. I have them in mine. It's a little rich in open loop, but fine once the O2 sensor heats up. Are you saying your spark plugs are wet?
As for the ALDL, try to clean and tighten the grounds on the back of the passenger side head.
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
