LOCATION OF STARTER SWITCH NEED ASAP
Old Apr 7, 2009 | 03:05 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Okay. this is my problem. i have a new starter and new batt. turn over the key and nothing there was smoke under the dash. when the car was running i turned off and when i did that and tried to turn over it won't start. i checked everything fuse and all. i am thinking its the starter switch. where is that located is it in the steering column or outside the steering column????? please just tell me where its located much appreciated.
Old Apr 7, 2009 | 04:00 PM
jaygod8's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 2.8L V6
Re: LOCATION OF STARTER SWITCH NEED ASAP
It should be about 1/3 of the way down the column (Mounted to the column basically under the guages). I've had two different Sport Coupes and on both I had to loosen the column to drop it low enough to get to the starter switch.
Old Apr 7, 2009 | 04:01 PM
berlin305's Avatar
thank you so much. so far i have the steering column assembly apart. i need to know have u ever had one that smoked?
Old Apr 7, 2009 | 04:03 PM
berlin305's Avatar
And since i knew my starter was bad would it give it to much current to make that actually fail? b/c it smoked numerous times this time it failed.
Old Apr 7, 2009 | 04:12 PM
jaygod8's Avatar
Engine: 2.8L V6
Not sure about the starter causing the smoke but on my 87 SC it smoked 6 times before it died!! All I did was change the switch out and it worked for the next 30,000 miles before I sold it to a friend. Her B/F totalled it two weeks later!! *jerk* I loved that car, but sold it to her cuz of some bad memories! lol
Old Apr 7, 2009 | 04:18 PM
berlin305's Avatar
yea starter wasn't smoking but the under the dash was and couldn't find the smoke coming from figured it was in the column. was it easy to fix. yea i am not selling mine lol. i am keeping this even if it costs me in the long run.
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
5spdcamaro
Aug 28, 2015 02:12 AM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
