Wont Start
Old Apr 6, 2009 | 06:18 PM
tri power's Avatar
Wont Start
I replaced the ignition key in 92 z-28 when you turn the switch on all lights in dash come on the starter will not turn the engine over I checked the fire under the hood to the starter it is good I replaced the ignition switch on the bottom of the steering column where it plugs up I checked the key with a meter it reads good I have the antitheft hooked up or VATS why isnt my starter turning the engine over starter is good.
Old Apr 6, 2009 | 08:57 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: Wont Start
i have the same problem i put new starter in but have not changed the ignition starter switch where is that located? any pics?
Old Apr 10, 2009 | 09:52 AM
tbob604's Avatar
Car: 2003 F150/1992 Camaro RS
Engine: 450hp 327 carb
Re: Wont Start
Sorry I'm getting to this so late, and I hope you have it figured out by now, but if not then it may sound stupid but make sure your in neutral or park and also that your neutral safety switch is good. If your trans selector shows "N" or "P" and it's still not doing anything, try wiggling the selector around while you keep trying to start the car, sometimes things get funky under there and you do what you have to do. Hope this helps.
Old Apr 12, 2009 | 05:27 PM
berlin305's Avatar
Re: Wont Start
i fixed mine it was the ignition starter switch and i went ahead and replace teh starter and my neutral safety switch all at the same time if one goes the other is bound to be weak to go. and btw put a new steering column in form a 91 firebird worked like a charm. now urs could be u didn't adjust ur ignition starter switch correctly maybe. but the neutral safety switch is sometimes teh colprit.
Old Apr 12, 2009 | 08:07 PM
quickbrad's Avatar
Car: 86 IROC
Engine: 355 TPI
Transmission: JUNK
Re: Wont Start
Does the new key have the same size resistor that the old 1 did?
Old Apr 12, 2009 | 08:08 PM
whitealexander's Avatar
Re: Wont Start
LOL i have the same problem too.. never thought it was that easy to fix..
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
