gas gauge help
Old Apr 7, 2009 | 12:51 PM
r-borgmi's Avatar
gas gauge help
well i decided to go with all a/m gauges and the only thing im going to have a issue with is the gas gauge. will a a/m auto meter gas gauge work with a stock 86 camaro fuel sending unit ? if not what are my options i would rather not go with a a/m fuel tank and i have allready converted the fuel sender for carb use. thanks all
Old Apr 7, 2009 | 07:16 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: gas gauge help
Ok well it makes sense you would have to use the same one. but i think it should work it all works on electricity unless you going to mechanical gauge then you would have to change.
Old Apr 7, 2009 | 10:19 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: gas gauge help
Not all gauges and senders are created equal.
You'd need a gauge that shows empty at 0 ohms and full at 90 ohms.
Hope this helps.
Lou
Old Apr 8, 2009 | 12:17 PM
r-borgmi's Avatar
Re: gas gauge help
have you used an a/m gauge on your stock sending unit lou ?
Old Apr 8, 2009 | 12:23 PM
BigBadLou's Avatar
Engine: TPI
Re: gas gauge help
No, my car is stock, no aftermarket gauges.
I just did the homework for you and found out that Autometer does carry 0-90ohm fuel level gauges. As an example, product #2641.
So when you find your favorite style, make sure the gauge you get has the 0-90ohm range.
Hope this helps.
Lou
Old Apr 8, 2009 | 04:14 PM
r-borgmi's Avatar
Re: gas gauge help
man thanks for all the help.
Ghettobird52
Jul 5, 2024 11:18 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
