Another Temp Gauge ? Sorry
Old Apr 8, 2009 | 03:22 PM
Timmy2500's Avatar
Car: '86 Z28
Engine: 5.0
Transmission: m39
After reading thru 100+ temp gauge threads I still need an answer
Temp gauge sits a min untll I plug the sender on the block in then it pegs to max, unplug it it goes back to min is there a problem with the sender, gauge, or wireing?
Thanks, Tim
Old Apr 8, 2009 | 05:12 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: Another Temp Gauge ? Sorry
Unplug the sending unit and see what the gauge does.....Then replace the sending unit. They are not that expensive from your favorite auto parts store.
Old Apr 8, 2009 | 06:18 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If it pegs to max when you put the wire on the sender, the odds are very high that it's a shorted/bad sender unit.
If you want to troubleshoot it more before replacing it, you'll need a multimeter to measure the resistance of the sender. Let me know if you'd like to try that.
Hope this helps.
Lou
Old Apr 9, 2009 | 04:49 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Mine does the same thing all i did to fix it. was put a new gauge in since the sensor is not cheap its 90 dollars compared to the 30 dollar mechanical water temp. But yes it could be a short or a bad sensor.
Bubbajones_ya
Jul 6, 2024 08:32 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
corey8084
Sep 17, 2015 02:56 PM
