Parking brake dash light lit. stays lit? Y my friend.
Old Apr 11, 2009 | 10:17 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
I was wondering y my dash brake light is on, it say brake. like the parking brake is on. but its of.. so that mean that i need to change my brakes and hope the best please help. GRR
Old Apr 12, 2009 | 11:33 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Parking brake dash light lit. stays lit? Y my friend.
The easiest part to get to right now is the brake differential pressure switch on the brake master cylinder under the hood. Unplug it and if the light turns off, that's your problem. However, you'd have to determine whether the switch itself is bad or whether you have a brake system problem (air in the tubing).
Another switch that actuates this light is in the center console on the emergency brake. If you unplug it and the light turns off, that's your culprit.
If neither of these switches causes your problem, you might possibly have a chafed wire touching ground but it's too early to think about that.
Hope this helps.
Lou
Old Apr 15, 2009 | 10:33 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
its prob the stupid ground on the handle itself i pullt it loose when i changed the carpet check that it may have come loose
Old May 16, 2009 | 01:32 PM
with some testing finally, i found out, that is my master cylinder and combination valve. the seals are failing, rez is black coffee. I propose that i swap the master, the combination valve, and the 24 year old switch with new parts, and bleed the brake system. im going to also swapp for some new rotors, and some pads, bearings, new seals. ill take pictures and have a step by step procedure. if its an "approved way" of repairing the situation, maybe it can be a sticky...-mikey
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
