9th injector draw...
Old Apr 14, 2009 | 10:46 PM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
ok so i recently installed the mini ram to my 383 and the 9th injector is gettin power and its draining my battery big time. the cold start 9th injector wire plugs arent hooked up (obviously) cause theres no place for the to be hooked up to. so my ? is wat should i do? the connectors are continuously gettin power when the car is off causing the battery to die. wat should i do? please help. thank you
Old Apr 15, 2009 | 01:28 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: 9th injector draw...
You say that the 9th injector isn't hooked up anyway in which case it cannot cause a current draw.
If the plug has power with the key off, though, I'd check what other parts of the engine get power with the key off (look for pink or pink/black wires). It might be a problem in the ignition switch.
Hope this helps.
Lou
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
ronchic
Mid-Atlantic Region
Sep 15, 2015 08:04 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
