Fuse blowing at WOT
Old Apr 21, 2009 | 10:15 PM
CBerlinetta85's Avatar
Fuse blowing at WOT
I have a 1985 Berlinetta 305ci carb and when evr I go to WOT or about 3/4 throttle the "Gauge" 10 (red) Fuse blows. The insterment panal still stays on but the speedometer stays at zero. I cant find anybody that would have a solution for this.
Old Apr 21, 2009 | 11:12 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Fuse blowing at WOT
Does it happen even if the engine is not running? (with key on, of course)
If so, you could unplug the TPS and try again. Then I'd unplug the Mixture Control Solenoid, the Air Diverter Valve, the Air Select Valve and the EGR solenoid. If the fuse still blows, I'd unplug the ECM.
If fuse still blows, I'd start unplugging random things because then I wouldn't know anymore.
Lou
Old Apr 22, 2009 | 12:41 AM
I dont think that the fuse blows unless the engine is running,I have a carb with all the emission stuff tooken off so basicaly everything is unplugged...
Old Apr 22, 2009 | 10:45 AM
BigBadLou's Avatar
Engine: TPI
I see. Do you still have the Mixture Control Solenoid? I would unplug that one and test WOT.
I am really not 100% familiar with the CCC setup, I hope somebody chimes in with more advice.
Lou
Old Apr 22, 2009 | 11:09 AM
I have an edelbrock carb and unlike the rochester its not computer controlled. The only things pluged in the carb is the auto choke.
Old Apr 22, 2009 | 11:36 AM
BigBadLou's Avatar
Engine: TPI
I see, so you don't have the ECM either? Now we're on the same page.
In that case, I'd look at the carb and try to locate any kind of switch that could be triggered by the throttle position.
Otherwise, there isn't anything I can think of that would be throttle position dependent on carbed cars.
Lou
Old Apr 26, 2009 | 12:00 PM
DaveBerlinetta's Avatar
Car: 1985 Berlinetta
Engine: 5.0 LG4
Axle/Gears: 3.08 Peg Leg
It sounds more like the throttle pedal is contacting something under the dash. Maybe rubbed through a wire, shorting it out. Did you do any work under the dash?
Old Apr 26, 2009 | 02:30 PM
I havent done any work with the wires other then trying to figure out the problem but I'll check under the dash and see if any of thats is happening
Old Apr 29, 2009 | 09:35 AM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Double check that youre using the correct amp fuse.....I could have swore the gauges ran on 15amp fuses.
Old May 1, 2009 | 04:41 PM
No Im 100% sure it is a 10 amp fuse...so far for an update I have completly unplugged the ECM and the fuse is isnt blowing anymore for now...
Pac J
May 17, 2020 10:44 AM
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Damon
Sep 26, 2015 04:29 PM
