Alternator troubles (sad face)
Car: 1985 Camaro
Engine: V6
I just replaced my heads, so I had to pretty much tare apart the entire engine bay. I wasn't 100% on where everything hooked up (partly because I learned a good way to label things after it was torn down to the block
....). Right now I am getting no alternator at all.. I had to take it off the bracket but I don't think that I took any wires off or disconnected anything for the alternator... But I do have a random plug (that I don't know if it was hooked up before) that comes right off the alternator. It is a brown wire and a red wire on the plug. Here are some pics of it, if someone knows where it plugs into and if you could get a pic of were it plugs into it would be great.
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: Alternator troubles (sad face)
That plugs into the alternator . By looking at the way yours mounts it should go at the bottom of the alternator .
raymondandretti
Sep 27, 2015 06:43 PM
