Water in Hella E-code housings
Old Apr 27, 2009 | 02:57 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Hope I have the right forum for this (maybe it should be called electrical?).
A few years back I installed Hella E-codes. Recently I've noticed water in the passenger side capule. The rubber cap and connectors all look ok, and the driver's side does not suffer from this problem. The housing isn't cracked either.
Any ideas?
Old Apr 27, 2009 | 03:17 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Water in Hella E-code housings
Sadly, If you've got condensation there has to be a pinhole or hairline crack there somewhere for moisture to enter.
Old Apr 29, 2009 | 11:57 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
You may still be able to save this housing. Check to make sure the adhesive/seal between the lens and rear of the housing is not split anywhere. While not the most beautiful fix, you could try running a thin bead of clear silicon to fill in any gaps.
Bubbajones_ya
Jul 6, 2024 08:32 PM
69GTOby
Apr 18, 2016 02:34 PM
jrdturbo
Mar 31, 2016 02:58 PM
customblackbird
Oct 1, 2015 04:30 PM
st.evel07
Sep 19, 2015 09:24 PM
