Hatch release with pull-down motor?
Old Apr 27, 2009 | 03:20 PM
cyberleader's Avatar
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
My pull down motor seems to be draining the battery for some reason, and I don't see the point of it anyway to be honest, so I'd like to disconnect it and just use the hatch release. Before I start any surgery, I there any reason this won't work?
Cheers Tom
Old Apr 29, 2009 | 01:10 PM
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
Re: Hatch release with pull-down motor?
Put another way, I want to disconnect the pull down motor but still have the power hatch release. if this possible?
Old Apr 29, 2009 | 02:54 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
It will work. But it won't work well just by disconnecting the motor. My motor is currently disconnected because the gear housing is broken yet again. The release still works. The extra bit you need to do is secured the latch to the body panel somehow (and at the right height). I've just rigged it with some wire to prevent the latch from moving down and breaking the gear housing even more when I'm closing the trunk.
I've noticed that it's hard to get the hatch closed tight enough for it to stop rattling. Although, I have my hatch seal reinforced with surgical tubing, so it doesn't have as much give.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
smooth
Aug 18, 2015 06:34 PM
1nastygta
Aug 8, 2015 07:38 PM
