fuel pump / sending unit need help
Old Apr 28, 2009 | 12:00 AM
v8 drift's Avatar
Car: 84 Z28
Engine: 355
Transmission: t56
Axle/Gears: 4 11
ive got an 87 iroc 305 tpi the guy i got it off said it ran fine till i just died one day so i started to trouble shoot it its getin fire and will sputer if i spray a little gas down the intake i couldnt hear the fuel pump coming on so i checked the fuses and relay they seemed good so i ordered a pump i decided to put an acess panel in the trunk so i get the pump put it on and nothin i dont have a volt tester but i can tell its not geting full power cause the test liegth isnt as briegth as it should b also the purple wire is the only one with power y does it go to the gaudge only and not the pump the pump positive is grey but when i test the incoming grey its dead ive been trying to get some wiring diagrams to help me out cause the harness has been cut a few times so maybe its shorting out somwhere
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
