Wiring Guages.
Car: 1985 Trans Am
Engine: 305 TBI
Wiring Guages.
Okay so ive talked to some people and have decieded the way im going to wire my auto meter guages in is from the wires already there. What i need is a wire diagram showing which color wire need to wired where for the certain guages. I appreciate the help, i used to have a page someone gave me but i lost it unfortunately and cant find anythign anywhere.
Car: 1992 Camaro RS
Re: Wiring Guages.
Car: 1985 Trans Am
Engine: 305 TBI
Re: Wiring Guages.
I need some more help, ive wired everything in, but the diagram doesnt show the colors for the gas guage could someone help me out? Also, what wire should i splice to wire in the guage lights?
Car: 1985 IROC Z28
Engine: L98 - 350/650 Holley DP
Axle/Gears: 3:83 Full Spooled
Re: Wiring Guages.
whenever i add gauges or lights and want them to be able to be dim down like the factory i just wire into the factory dim switch or in our case the headlight switch. if you are just wanting them "on" when the lights are on, wire them into the headlight wire on the same switch. if you want them "on" when the car is on, head on down to the fuse panel and plug into your heater fuse (i prefer the heater fuse because if you accidentally blow it at some time, you are only out your heater fan and not something important!)
Glowsock
Jan 9, 2017 04:06 PM
