VATS Questions
Old May 2, 2009 | 10:38 AM
zombielord's Avatar
Car: 83 Camaro Z/28
Engine: 87 5.0L TPI
Transmission: TH700-R4
VATS Questions
First let me say hello since I am new to the forums.
Some background info:
1983 Camaro Z/28, 1987 IROC 5.0l TPI Engine, Aftermarket TPI Wiring harness, Engine converted from MAF to 90-92 Speed Density system, ECM #1227730 EPROM #16163139
Since the body is a 1983, I have no wiring from the ignition cylinder for VATS, I have no wiring coming from the door lock cylinders for VATS, I have no VATS module or any other wiring. I know the stock EPROM comes with the VATS enabled. I am going to double check the wiring harness, but if I remember right from when I put it in, there is no wiring for the VATS.
Questions:
1. If the ECM/EPROM has nothing to communicate to or from, is the VATS a factor? I hate to have to buy all kinds of stuff just to bypass the VATS (I'm on a tight budget here).
2. Do I need to have the stock Eprom reprogrammed to have the VATS disabled to avoid all the problems with VATS?
3. If there is no associated wiring for the wiring, can I just ground the starter enable relay and not have to worry about the VATS on the eprom?
I would really like to know before I plug in a 210 dollar eprom and try to start the car and possibly damage the eprom.
Thanks for your time and input on this
Quick update: I double checked the TPI harness, the 32 pin green ecm connector has no wiring for the VATS (GF10) is empty.
Old May 2, 2009 | 10:46 AM
Heslekrants's Avatar
Car: 1990 Camaro RS
Engine: 5.7L Vortec TBI
Transmission: Built 700R4 2800 stall
Re: VATS Questions
You should be able to tune out the VATS. I'm running a Caprice Cop chip and the VATS is disabled. Guess the Cops are too worried about somebody stealing their car.
stalkier
Dec 6, 2015 11:25 PM
WIzmo
Aug 30, 2015 02:30 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
