1988 FIREBIRD FUEL SYSTEM WIRING
Old May 2, 2009 | 12:48 PM
FireMcBucket88's Avatar
Hi, i have a post in the TBI section that has all the information about my car. At first i thought it was a fuel pump issue but i have figured out that it is an electrical problem. The fuel pump motor is not getting power to it (i have checked continuity). The relay clicks on and the ignition switch turns on the radio, ac, lights, etc. I have discovered that there is a switch between the relay and the fuel tank. where is this located? if you dont think this is the issue, what is?
Old May 2, 2009 | 08:50 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: 1988 FIREBIRD FUEL SYSTEM WIRING
There is no switch between the relay and the fuel pump, only one connector, the infamous C313.
You can follow this troubleshooting article and see which component of your fuel pump circuit is faulty:
http://www.austinthirdgen.org/index.php?pid=35
Hope this helps.
Lou
Old May 2, 2009 | 11:29 PM
thank you for the help lou. that plug is where i was going to go next. but im thinking i might just hardwire the fuel pump to a toggle switch and just bypass everything completely. but ill only do this if the C313 isnt the problem. I think that the problem may lie in the electrical system due to my brothers stereo when he drove the car 3 years ago. but dirt solidifying whilst the car sat for 3 years does make perfect sense. ill be under the car tomorrow afternoon eager for some progress!
Old May 3, 2009 | 12:15 AM
BigBadLou's Avatar
Engine: TPI
I would recommend against a switch-powered pump. It is very unsafe and gets tiring after a while.
The ECM controls the fuel pump just right, as long as the wires and relay are ok. It's a very simple circuit, not much that can go wrong with it.
Lou
Old May 3, 2015 | 09:06 PM
NFSP_Birdy's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
Transmission: Automatic
*bump* Hey there, was just curious how this task went for you if you ever did it. I'm having similar issues on my 88 Bird. Instead of a toggle switch though I'm going to run a straight cable to the c313 switch with an inline fuse. Thoughts?
Old Mar 24, 2016 | 06:26 AM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Just what i needed, a troubleshooting article. Cool.
BRoss99
Aug 10, 2025 05:08 PM
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
Caspar
Jun 19, 2016 11:19 PM
Randomtask2
Aug 13, 2015 01:57 AM
