ignition switch
Old May 5, 2009 | 07:32 PM
92formula12's Avatar
Car: 1992 Firebird Formula
Axle/Gears: Posi
ignition switch
please i need some ones help i just replace my intake manifold gaskets and now i need to replace my ignition switch i need to know wat to do i have the column tooken apart down to the turn signal switch i heard all u have to do is drop the column let me rewind wen u turn my key nothing happens but i have power engine dosent crank and i dont get nothing on the dash ive looked and it seems the pushrod isnt connected to any thing but its real short i just need some ones help please and thank you
Old May 6, 2009 | 07:41 AM
jaygod8's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 2.8L V6
Re: ignition switch
Take the plastic pieces off from under the column and you will see a metal U channel surrounding the column with a 13mm Nut on both sides. (also has some bolts connecting it to the column) Remove those nuts and the column will drop down.
Old May 6, 2009 | 10:39 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: ignition switch
The first thing I'd do is go back to school and learn punctuation and how to use it. I am not a teenager texting on a cellphone all day and I can't read something that doesn't look like English. I was respectful enough to learn your language so it might be nice if you did the same, thank you.
The next thing you could do is find out why the ignition switch doesn't give you power to the dash, before you replace it. As Jason said, you can drop the steering column and the ignition switch will be sitting on top of it, about a foot down from the ignition cylinder. If the rod isn't connected, it would explain why the switch doesn't do anything. If you can reconnect the rod, that would be good. But if the switch is busted (the car could have been stolen in the past), it would need to be replaced.
I guess we'll have to wait and see what you find when you drop the steering column and then we can take it from there.
Hope this helps.
Lou
Old May 7, 2009 | 04:44 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: ignition switch
I have an manual here : http://www.iroczone.com/forums/viewtopic.php?t=34298
how to change the ignition switch, cannot write it here due only 5 pictures are allowed in each post, I have 25 in that thread.
EDIT: 2nd post by Theking you have it
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
luvofjah
Sep 3, 2015 07:08 PM
