ok new VATS lock cylinder new key...
Old May 6, 2009 | 06:13 PM
Canadianguy2006's Avatar
Car: 1990 Trans Am GTA
Engine: 350(5.7L)
Axle/Gears: 3.23 posi
ok i changed out my old vats lock cylinder today with a new vats cylinder, i have the proper coded key for the new cylinder but when i plug the pigtail into the female connector under the dash it won't start, now someone before me used a resistor on the female part and the car starts no probs, any ideas why the key isn't working?
Old May 6, 2009 | 07:48 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: ok new VATS lock cylinder new key...
Did you get the new key made with a 'new' code, or with the old 'code'? Unless you changed out the VATS computer under the dash, you have to get the new key made with the old key's resistance - the VATS is looking for the resistance from the old key.
Old May 6, 2009 | 09:23 PM
Engine: 350(5.7L)
did that the resistance on the new key is the same as the old one, and the vats module is still original
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
90formulaVortec
Sep 7, 2015 06:54 PM
