window motor problem help
Old May 7, 2009 | 11:25 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
So every time press the button to make my window go down it stops about half way and then i have to stop and start to push the button againe. IS my window motor on its way out. if it makes any difference my driver side window is much faster. thanks
Old May 7, 2009 | 11:35 PM
95camaro85ta's Avatar
Car: 1985 trans am
Transmission: t5
Re: window motor problem help
yes your motor is goin out
Old May 8, 2009 | 12:39 AM
HAWAIIFISH's Avatar
I would run to wires into the two wires on your motor. Put one on the positive and the other negative. This should either roll up or down. Reverse the wires and once again either roll up or down. If this works your window just fine then it is a possible that the switch is going bad.
Old May 8, 2009 | 06:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The window may simply be misaligned at the guides and is binding. The thermal switch will overhead and stop the motor.
JamesC
Old May 8, 2009 | 08:02 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
after 20 yrs. a build up of dust & dirt can/will cause problems . remove door panel & plastic sheeting . clean & lube all linkage and tracks . inspect & repair any other faults you may find . i have used mineral spirits in a spray bottle to clean and white lithium spray on linkage then silicone spray on tracks . has worked for me in the past . remove rubber drain plugs on bottom of door & clean inside of door ( no telling what you may find ) . test and re-install everything . don't forget plastic sheeting under door panel . i got mine at home depot & installed with hot glue gun . has worked for me and friends many times over the years . good luck .
Old May 8, 2009 | 10:25 PM
Car: 91 formula
well here an update. the window is making a whine noise. when i put the window up or down.
Old May 9, 2009 | 04:57 AM
HAWAIIFISH's Avatar
MOTOR ISSUE. DID YOU TRY THE TWO WIRES STRAIGHT TO THE BATTERY?
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
stalkier
Aug 13, 2015 12:59 PM
