what is this wire under intake?????
Old May 10, 2009 | 09:15 PM
gaskincrew's Avatar
i have a 5.7 tune port, there is a 1 wire sensor with a connector on it looks like a o2 sensor plug, anywho when i plug it up my engine light comes on uplug it it goes out, runs fine just what is it? close to egr valve...
Old May 11, 2009 | 12:20 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: what is this wire under intake?????
EGR tempature switch. check out this web page. good luck man.
http://chevythunder.com/fuel%20injec....%20pg%20B.htm
Old May 11, 2009 | 01:05 PM
gaskincrew's Avatar
so is this sensor need replaced on egr valve, looks like a tough one to get to, but pluged up light on unpluged engine light off.
Old May 11, 2009 | 01:19 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
dont know where you are and if its a maf or map system but the egr is federal mandated - you need to make sure it works if you operate on the street.
it tells the computer some important things to get the best performance out of your camaro.
you can get an aftermarket egr here http://cgi.ebay.com/ebaymotors/ws/eB...%3AIT&viewitem=
there are probably other places i just happen to have that one up.
Old May 11, 2009 | 02:12 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Have you pulled the code for the check engine light? Is it 32 for the EGR system or something else? That would tell you a little bit about what's wrong.
Lou
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Jake_92RS
Aug 11, 2015 10:39 AM
